Hdc318 lower notes?
You can build a new enclosure. 5.5 is far to small for that 18. Minimum I have ever used was 6ft3, but in honesty they like even larger then that.
It is hard to base anything audio related off of other's builds.
AQ's love large enclosures. Sorry but no way around that what so ever.
aq's love small boxes not large, they need gigantic ports and small chambers.
aq's t/s are pre broken in, and worth less. I say run an abc box,
2.6ft first chamber, 1.3 second chamber.
45'' of port big chamber tuned to 30hz and second tuned to 42hz
Trust someone who worked for AQ and builds boxes as a semi-significant part of his income... or trust someone who's an asshole who honestly believes he knows everything about car audio?
The choice is yours.
Me thinks this is going to turn into a pissing contest
Naw, I posted what needed to be posted. Everyone is allowed to have their own opinions. The OP has been given info and can do what ever he likes with it.
OP-
Post up the specs to your enclosure. HxWxD(list any double panels, 45s, or bracing used) also post up your port h x w and the length so we can get an idea on your enclosure to better assist you.
I like pissing contests, Pro-Rabbit I challenge you!
To do so you have two choices to pick from,
Destroy the enclosure I built you on video first...then you may challenge me..
The other option, you have to hold it for me while I'm pissing....
take your pick sir.
Your output dropping off dramatically below tuning is pretty standard. As others have said, a larger box, lower tuning, and experimenting with different positions or firing sub and or port in different directions often makes more of a difference than anything.
Lowflyin
Sit on my face, B*tch
Lowflyin
FU JOSE, PA
wenn_du_weinst
vegang
vegang
