Completed Sundown SDX-100.6 6 channel amplifier $285 shipped Lower 48
Doxquzme
Premium Member
Current build, 2012 Mazda 3 Hatch 2.5T
Price
$285
Condition (1 worst - 10 best)
10
Boise, ID
This guy is brand new, open box and bench tested to work as advertised. Part of two builds last year that went south. Hefty little guy, built like a tank. Metal pots adjusters and wide range x-over options.
  • 300 x 3 @ 4 ohms RMS Bridged
  • 150 x 6 @ 2 ohms RMS
  • 100 x 6 @ 4 ohms RMS
  • Variable 12dB high-pass filter: 15Hz - 500Hz or 300Hz - 10kHz (Ch. 1-2)
  • Variable 12dB high-pass filter: 15Hz - 500Hz (Ch. 3-4)
  • Variable 12dB low-pass filter: 15Hz - 500Hz or 300Hz - 10kHz (Ch. 1-2)
  • Variable 12dB low-pass filter: 30Hz - 500Hz or 600Hz - 10kHz (Ch. 3-4)
  • Variable 12dB low-pass filter: 30Hz - 500Hz (Ch. 5-6)
  • x1/x20 crossover frequency multipliers
  • DC auto-sensing turn on
  • Thermal, voltage, speaker short, and dc-offset protection circuitry
  • Water resistant
  • Heavy cast aluminum heat sink
  • Removable audio control cover
  • Optional wired remote control
Get ready to experience the power and versatility with the water-resistant SDX amp! Perfect for your car, UTV, or any open-air vehicle, this compact yet mighty Class D amplifier delivers exceptional fidelity. Neatly protected beneath a sealed cover, a full suite of audio controls allow you the freedom to adjust your sound to perfection. A robust aluminum casing provides superior heat dissipation, and a shield from the elements. Whether its powersports or in your daily driver - with the SDX amp, you get great sound - for years of fun in any weather!
Product Manual
Specifications​
  • S/N: >78dB
  • Input sensitivity: 6V max
  • Working voltage: 11.5 - 15V
  • Recommended fusing: 80A
  • Dimensions in Inch (L x W x H): 12.25" x 7" x 2.125"
Note: Unscrew the badge using an allen key to access audio settings.
Was Photo Included
  1. Yes
Was Note Included
  1. Yes
Title Suggestions
  1. Not right now
Doxquzme
Premium Member
Doxquzme
Boise, ID
Doxquzme
Bass Addict
    May 11, 2025
Bass Addict
    May 11, 2025
