pimpnyou204
Just looking for a real quick anaswer basically. Ive heard different views from shops etc. But if you have a battery in the trunk 1/0 from front batt to back batt then 1/0 grounded from negative on battery. Now if you have 2 amps i was told to ground to what ever is the nearest and never ground further than 4 ft. Which is better grounding to negative on battery, to the spot on the car where the battery is grounded or to the car in a completely seperate spot?
Also if you ground to the battery with 1/0 wouldnt you need to add another another 1/0 from the battery to the ground so you have equal resistance?
