Grounding to battery or car
pimpnyou204
Just looking for a real quick anaswer basically. Ive heard different views from shops etc. But if you have a battery in the trunk 1/0 from front batt to back batt then 1/0 grounded from negative on battery. Now if you have 2 amps i was told to ground to what ever is the nearest and never ground further than 4 ft. Which is better grounding to negative on battery, to the spot on the car where the battery is grounded or to the car in a completely seperate spot?
Also if you ground to the battery with 1/0 wouldnt you need to add another another 1/0 from the battery to the ground so you have equal resistance?
That is what I was thinking but if u have 2 1/0 runs to the battery negative u also have to have 2 more runs (2 from amps, 1 from front batt = 3) correct?
If you have 270 amp alt
370 amp sub
110 highs amp
This would require 3 right because a 1/0 can carry 300 amps?
---------- Post added at 07:08 PM ---------- Previous post was at 07:08 PM ----------
Also all 3 grounds from the battery can be grounded at 1 spot on the car?
370 amp sub
110 highs amp
What the hell are you running?!
I guess what im asking is how much wiring am i gonna need.
Dc 270 amp alt
AQ 3500d 370 amp draw
soundstream rubicon 4.600 120 amp draw
With that much draw i currently have..
2 1/0 + to back batt or is just 1 run good enough?
Then i could just run my amps - and + to the back batt as a distro
Now how many runs of - would i need from back battery to ground? Match my + runs to the battery currect?
I guess what im asking is how much wiring am i gonna need for...
Dc 270 amp alt
If you can, just run 1 ground from back batt(s) to a mounting bolt on your alt.
might save you a couple feet of wire. I have a similar amp draw as you and only have a single run of 0Ga
very minor volt drop....like .2 -.4 which is nothing.
Dc 270 amp alt
Let's take the AQ3500- if and I do mean if you get 3500w out of it at 12v, that's 273A. That would be on a full draw for probably 40/1000s of a second on a perfect note. More realistically, between imp. rise, variance between notes, and having voltage that stays 13.5+: you would be looking more like a 222A draw maximum (giving the AQ a generous operating RMS of 3000w) and more like a constant draw of 100A. Between your two amps, the alternator itself should more than keep up with the current draw with 1 1/0 run from it straight to the back battery.
That said, it never hurts to have overkill. I wouldn't expect 370A draw out of anything less than an 8k amp, however. Not an operating draw at least.
.02
.02
Bingo
If you have a unibody car, you should ground battery to battery, but if you have a solid frame to ground to, it is perfectly fine to do that instead.
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
Oh ffs...he's jumped a car twice and is now an expert on car electrical systems 🤣🤣🤣
981
I had a really hard time with my 1990 240sx. That had to have been the hardest car to wire up and install to date. The doors were something else
pimpnyou204
pimpnyou204
Fort Lauderdale
Chriszle
Dan Medina
    Jun 17, 2024
    Jun 15, 2024
