Grounding Amp and Cap
  • 4
What kind of amp and how many watts, the cap may do more harm then good if your going to be drawing a ton of current on a stock electrical system. A cap only works to keep small dips out of the voltage when the current in the car is higher then the draw of the amp, if the draw of the amp is higher then the stock alt output then your cap will discharge on some notes as your alt kicks out from strain and keep your voltage down even longer due to the fact the cap now has to recharge on the next lull in the bass to try and play catch-up.
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
Oh ffs...he's jumped a car twice and is now an expert on car electrical systems 🤣🤣🤣
968
I had a really hard time with my 1990 240sx. That had to have been the hardest car to wire up and install to date. The doors were something else
Memphis2011
Memphis2011
Maryville,TN
FlexnInLa
