Ground Distribution Blocks?!?!
  • 4
nofriends46
I have two amps, cap and one electronic crossover, my both amps & cap is 8 guage for ground. My electronic crossover is just like speaker wire type, like 20 or something.
Should i run all ground wires to my ground dristribution block?
My ground excepts 4 8 gauge output and 4-8 guage output. If i do, what should i use 4 or 8 guage? Or should i just run my amps and cap, not the electronic crossover?
Does the ground wire needs to be a certain length to the ground distribution block?
If so, how long, my amps are like 2ft apart and my electronic crossover is 3 ft away from the amps or less, the cap is close to the amp.
Thanks!
u dont need it really but it makes the job look nice if u do use one i wouldnt run the crossover off it the just the amps and the cap. no there isnt any set distce it has to be just make sure that is a good groud.
Ground the distibution block using 4 awg wire no longer than 18 inches. The shorter the better. Then ground all amps, crossovers, ect. to the distribution block.
You would most likely want to send a private message to Chris229, he is our signal expert, he would be able to walk you through steps to help you eliminate the source of the problem.
I'm guessing that's what it is. There's not a lot of room back there.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
Yeah I saw a lot of that when doing those installs as we also did surround sound system wiring as well. I always ended up being the doing it as...
nofriends46
nofriends46
Hawaii, Kauai
Phatillusion
    May 18, 2024
    May 18, 2024
