gorilla - no need to caulk?
use whatever you want...if the gorilla glue leaks, youll have to get silicone...I run a bead of silicon anyways, just to do it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
well considering its fiberboard and the construction adhesive I use says for use with fiberboard on it and since I have used both. I will stick with it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif my box weights over 90lbs with my subs and I walk around with it holding 1 handed and it doesnt have a problem staying together even with all the weight stress. I cant say ive had the same expierience of a wood glued box.
I dont think you understand.... wood glue forms a CHEMICAL bond... MUCH stronger than gorilla glue... by ALOT. Not saying gorilla glue cant hold a box together, it will, but wood glue is the best option. Talk to anyone that knows about construction, they'll tell you wood glue.
fancynapkin
fancynapkin
michigan
iamamp3pimp
