gorilla - no need to caulk?
use whatever you want...if the gorilla glue leaks, youll have to get silicone...I run a bead of silicon anyways, just to do it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
well considering its fiberboard and the construction adhesive I use says for use with fiberboard on it and since I have used both. I will stick with it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif my box weights over 90lbs with my subs and I walk around with it holding 1 handed and it doesnt have a problem staying together even with all the weight stress. I cant say ive had the same expierience of a wood glued box.
I dont think you understand.... wood glue forms a CHEMICAL bond... MUCH stronger than gorilla glue... by ALOT. Not saying gorilla glue cant hold a box together, it will, but wood glue is the best option. Talk to anyone that knows about construction, they'll tell you wood glue.
Have you spoken with one of the reps? They should have all that info on file.
649
424
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
474
fancynapkin
fancynapkin
michigan
iamamp3pimp
