Good sub (or subs) for around 300$
j4tk
Hi. Im new to the forums, well posting, and was wondering a good sub for around 300-350$. I have a 1997 Mitsu Montero, with third row seats out. I use yo have 2 pioneer champion pro 12, but sold them. Now I want back in the game. Was thinking Maybe 2 15s or a single 18. I have a hifonics 2500.1 amp. I'd be using it for daily use and
In that price range id look at the obsidian 18s...do you have 12 cu ft after port and sub disp to work with?
Would this be enough?
L:52 (This is with no passenger seats)
W:31
H:23 ( can be more, that's just below the where the window begins.)
thats 24 cubes
With mu backseats down. The dimensions would be: L:3' W:3' H:2' 18 cube ft.
If you want to use 24 cu you could run 4 18's or a bunch of other choices like 8 sq hd212's with a large port.
I would, only if I had the funds. :p really can't go more subs. I'd need an extra alt and another battery. Plus true 0 gauge. I have that soundquest sheet.
Obsidians work well in bandpass but the hds315 has a larger coil and will take the power better. You can build a 4th order there not that hard. I did a blow thru in a Buddy's s10 with a pair of 12type R's and it sounds amazing clamped only 726w. There are a few people on here that can design you a box and cut sheet. Suggest a 3to1 ratio tuned at 47-48hz.
why that tuning? I was thinking 30-32hz.
And yeah, my stepdad said bandpass boxes are the ****.
what all i really want is to be heard before im seen.
Bandpass boxes are supposed to be tuned high like that. The one I built was tuned at 47 and had a 4to1 ratio it was very strong from 30 to 45 hz and had decent output down to low 20's. The higher the ratio the more efficient but narrower bandwidth so a 3to1 tuned to 48 should do mid 20's to 50hz strong and peak in upper 30's. Trust me I'm running 2 15's on 5k and I was very surprised by the output of the type R's on so little power. I would do a 4th but mine are not very good for 4ths.
ah, alright. gotcha. You know anyone in particular that makes the bandpass'?
j4tk
j4tk
San Antonio
j4tk
