I have all the equipent in my sig file currently wired probably not optimally to work with my Alpine PXA-H800 DSP and am thinking I maybe should go ahead and go full active EQ at this point. I asked previously but it got buried in a while lot of meretricious piffle:
"I'm thinking if I have to do a bunch of rewiring I may just go full active EQ and use the 8 outputs of both amps to power the four 6x9s on the PDX amp and the PDRs outputs will be to the two 5.25" and their associated tweeters. Subwoofer still off the PDX just not under DSP control, at least directly. Does that sound like a feasible plan? Does to me! With the DSP I should be able to control each driver separately except the sub. Will that work? I know the one or two outputs from the DSP say they are for subwoofers, but can I use them for full range as well?"
Thanks, John Kuthe...
