Give up 15 for smaller sub?
Spl170s
currently have a oldschool kicker solobaric S15C in a sealed 1.5 cuft box. currently running off of 500rms. Amp is capable to 1 ohm at 1200 rms.
I am considering going to a set of 10's or 12's....possibly even ported.
music wise..i listen to about anything depending on mood. some heavy rock/metal, rap, r*b, hip hop......country....about anything. i think with that being said...sealed has always sounded the best...but doesn't seem to get as loud as i would expect.
that is where i am on this 15...i just expected more...but im not going to buy another amp right now. the sub is SVC4 ohm.
i have been looking at a set of vega vmax 10s or 12...probably 10s...
would i be stupid to consider giving up this kicker for a set of the vegas?
any other choices i should be considering.... im not going for spl per-say...just want to get loud when i want it....
budget.....150-200 tops shipped....i know i can get the vmax 10s for that range new.
also, in the trunk of a 2000 bonneville.
The vmax subs are nice for the price. Pretty good build quality and can get loud. They will be louder I'm sure.
P.S.
Sell me your solo //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
1. i think you should find some dual 4 ohm subs, something that'll like 600 per sub.
2. i think you should go ported, which is where i may be able to help you.. (i build boxes locally)
J31 I want the girl in your avatar on my face, NOW
OP - I havnt really heard anything about those woofers personally, I would consider a single nice 12" ported woofer for the power you have
everyone does.
and yes. this is also another good choice.. snag up a nice DD 1512 or 2512, they can be found for around that price..
everyone does.
The single 12 would be my route, probably a Mag or similar
Also, that girl looks very very much like a friend of mine, and man would Ilove to lick her up son haha
If youre in NW Indiana, make the drive over the IL border. I can meet you in south suburbs of Chicago or the city itself
2 12" Diamond D6 Subwoofers
Love 600rms each (what i give them now)
Small ported enclosure tuned to 30hz (good blend of SQ for ur rock and SPL for rap)
Even have an amp that does 1200rms that Im using with them now //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
PM Me if your interested
i am in logansport...only about 40 min from lafayette.
i was told not to go ported on this solobaric......also in the manual for the sub it doesn't rec doing that...so i just stayed away from it.
i build my own boxes as well....when i have time...2 little ones limits that these days though..
amp is 500x1 4 ohm, 750x1 2 ohm and 1250x1 1 ohm rms.
if i were to find something new, i would be selling this sub as well.
i have never heard diamond subs.... around here seems to be JL....what line of JL sub would be comparable to the diamonds? pm me more info on those and box size and such.
reasoni mentioned the vegas is becausei have always wanted to run a vega sub.....never had the chance to....not saying im stuck on it though.
my rear seat does have a fold down arm rest area too that gives access to trunk..."breathing" port..haha
PM Sent
That old solobaric has a pretty meager excursion capabilitiy. in s ealed systems, excursion (xmax) is directly proportional to output potential (multiplied times radiating surface area).
Get one of these new 'supersubs' with gobs of linear excursion.
1. i think you should find some dual 4 ohm subs, something that'll like 600 per sub.2. i think you should go ported, which is where i may be able to help you.. (i build boxes locally)
an RE SE fits that description perfectly, and will be your BEST sounding option //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
OP - budget.....150-200 tops shipped....i know i can get the vmax 10s for that range new. - OP
RE SE 15" would even fit in your enclosure at the compact airspace.
Huge gains going ported though, IM not sure on the price of one of these.. maybe not under $200
the Fi SSD 10" or 12" is under your budget shipped, 220 with Bp option.
Mach 5 IXl 15" is 220 right now, needs larger box though.heach 5 MAW 12 are sold out now but under budget for 2 of them.
KIcker compVR are 150 shipped form ebay for a pair same as vega Vmax for the 10"
the Vmax is really a good deal in the propper enclosure on 1200 watts it should do what you want.
$200 for 2 subs with 1200 watts is kinda hard to do, you end up lookign at kicker comps and Vmax, or used subs, classifieds still might come through with something awesome...
not at all bad subs in the orrect enclosure, but I woudl love to see you spring for a a Fi Q 12" ported on 1200rms. Sell the kicker first and see if you have enough for the Fi Q then. 259 shipped from Fi.
Spl170s
Spl170s
Indiana
skateboardkid
