getting three 10" id oem's
you shouldnt mix up different ohm load subs, they will recieve different amounts of power
if you had 2 d2 wired to 2ohm and a single d4 wired to 2 ohm then the d4 would get the same power as the pair of the d2's
i believe that is how it works but i have been wrong before.
~Magick_Man~
you shouldnt mix up different ohm load subs, they will recieve different amounts of powerif you had 2 d2 wired to 2ohm and a single d4 wired to 2 ohm then the d4 would get the same power as the pair of the d2's
~Magick_Man~
im not to sure either but i thought the amp see's only the final ohm and distributes the power evenly to each VC
somone who knows please post ... good thing to know for the future //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
well the amp does only see the final ohm load but if you have 2 d2 and a single d4
it would see 1/4 ohms.
with the 2 d2 wired to 2 ohms and the d4 wired to 2 ohms the power would be split evenly between the d4 and the 2 d2's.
so say your amp puts out 1000 watts at 1 ohms
the d4 wired to 2 ohms would get 500 watts.
and the 2 d2 wired to 2 ohms would get 250 each.
this would work but it would be less than ideal.
and again i could be wrong so if anybody knows something about this please correct me.
~Magick_Man~
The power is distributed based on the impedance of each subwoofer. In a "typical" setup, the impedances are equal, and hence equal power distribution. In a setup where there are different impedances involved, the power distribution will not be symmetrical or even and the subwoofer(s) with the higher impedances will receive less power.
V=I*R and P=I*V Those are the equations you need to know. The other thing that you need to know is that the voltage is the same in every load in a parallel wiring setup and the current is the same for every load in a series wired setup. If there is a combination of wiring break it up into sections and figure out each section.
For example if you have a 2 ohm and a 4 ohm load wired in series the final load is 6 ohms. You figure the total current using the equations above and then figure power for each load using the same equations. To make the math easy we'll assume 6W. That gives us 6V and 1A into a 6 ohm load. We can now figure out the power going to each load in the circuit. For the ohm load we get 4 W and we get 2W on the 2 ohm load.
If we now wire those loads in a parallel circuit and use the same voltage you would get 9W going to the 4 ohm load and 18W going to the 2 ohm load.
etznova
etznova
Cherry Valley, il.
etznova
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
