Galaxy S7 straight to DSP (no HU)
Roland
Atlanta
So i'm not sure yet what i want to do for a HU in my latest van.
So for now i just want to go straight from my phone to my JBL MS-8. I want the best quality connection possible.
Not sure whats the best way to do this, and not sure what i need. It would be nice to have a volume control knob also.
Oh yeah, i use Google play for my music.
Thanks for any help
you can use a 3.5mm to rca jack to aux in on ms8. but I would get an audio control four1, and go into that, then out to the ms8. and that basically is your line driver volume. ms8 is 2v max rca input and 2v max our per output. I doubt the galaxy is 1v
Thanks for any help
Good idea Thanks,
That Four.1i looks a little pricey, I might try the NVX (or Clarion) first to see how it does.
any cheap line driver would work but id imagine any dsp could handle that signal and amplify it to 2v rms without an issue. the gain would just need to be high depending on the input sensitivity (look it up for the dsp) so having an oscope to check the signal would be nice. pretty sure some have spdif input and there may be a way to get an optical signal out of your phone which most dsps will also accept.
If I'm not mistaken, a usb DAC (you could add steering wheel controls also with an otg hub) would be ideal here.... you could do everything including charge through one cable.
Sent from my SAMSUNG-SM-N930A using Tapatalk
I realize this is older yet I want to inform y’all I had a bad connection. A lead from the voltage sensor was crimped into the ground as it was...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
610
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
532
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Roland
Roland
Atlanta
Mahapederdon
    May 18, 2024
    May 16, 2024
