Gents,
I will be setting my gain via dmm this weekend.
A few quick questions, H/U is a pioneer DEH-3300UB, amp JL Audio E1400D, sub is a sundown E8 ver.4 in a slotted custom enclosure.
On the H/U, I know all audio settings, base, mid and high set to 0. Loudness off. How about the cutoff frequency (subwoofer #2 setting). It's currently set to 80 output level +2. Do I leave this alone or does it need to be changed and if changed to what?
On the amp, bass boost off. The slope on my amp is noted as LP Filter. I currently have set to 24DB. Does this get turned off or left at 24DB when setting the gain.
On the amp the LP frequency is currently set to 80hz. Does this setting remain as is when setting the gain or needs to be changed and if so to what?
I generally don't listen to the music louder than volume 40, mostly in the 30's. Would it be better to set at 40, I suspect it goes higher but I am not sure how to tell how high it goes since the manual does not advise maximum volume setting.
Thanks and any other pointers would be appreciated.
My first time doing this so would like to do it right.
