Gain starting vs end point
all my other gains are fine.. i was just confused as to why going down in voltage would increase the gain.. why is it like that?
Because the range is based on the voltage input.
If you were supplying it 9V of input signal, you would want the gain set to the minimum. If you only had .2V of input signal, you'd want the gain set to maximum.
Jakeeck
Jakeeck
Eutopia
squeak9798
