I have a 2012 Camaro with the upgraded Boston Acoustics system. My system includes:
Stock head unit
PPI 900.4 powering Polk db6501 front components (145w @ 4ohms) and 1 Infinity Kappa 100.9w (450w @ 4ohms) in a ported box.
I don't know the voltage output on my HU, and therefore don't really know how/where to set the gains on the amp. My HU goes to a vol max of 45, so I've decided not to exceed 25 and am guessing anything above that will clip on the HU. Just a guess though. On the amp I have both gains set to around 65%, but I think I want to bring the fronts down a bit because they seem to overpower the bass a little and also get a little muffled sounding in the 22-23 volume range. I don't know if that means they are clipping or just can't handle high volumes.
Do you guys know what my stock HU output voltage might be, or think that I'm safe at these gain levels? I tried the test tone and DMM ways of setting gains, but honestly the subwoofer was barely audible at the level my DMM suggested. I turned it up and the bass still sounds clean, although I suspect light clipping I wouldn't actually hear. Everything I've read about gain setting hints that you are trying to match the amp's voltage with your HU voltage, but without knowing my HU voltage, I don't know if I'm in a *safe* range.
Stock head unit
