Gain Control
jethrow
Is it safe to turn the amp gain control over half way? I was always told not to, but that was 8 years ago....my last system
amp is a JL Audio G-max
& a pair of Alpine R's ported box
the reason I ask is because its just "ok" at a hair under half way up
thanks~
ohms of speaker x rms ( of ethier amp or speaker rating ) whatever one lesser of the to ,divided by square root =what you want your dmm to read when set to ac voltage.
ex. 4 ohm x 75 rms = 300 divided by square root = 17.3
just set by ear, subs are easy to hear and listen. When its stops getting louder thats all your amp can do then back it down just a touch and you are good
Hah. Why would you divide by something's square root? If you divide anything by it's square root, you will get it's square root.
OP:
Set your head unit to 2/3 to 3/4 max volume, then adjust the gain until it sounds good and is loud enough for you. DMM's are for *******.
square root
300 square root = 17.3
vs. the square root
12x12 = 144
144 divided by the square root = 12
see the diff ?
thanks for the links
all hope is gone album has deemed my mirror useless, might as well take it off and use it as a hood ornament
those alpine R's hit clear and loud!
//content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
jethrow
jethrow
Green Bay
tryan77
BP1Fanatic
BP1Fanatic
