Fuses on a sub?
ahh the fuse is there for wiring purposes. instead of runnin another wire to the other voice coil you use the fuse instead, AND it also prodects the sub incase ya over power it
Note: The SureSet™ feature utilizes standard automotive ATC fuses to
select between series or parallel voice-coil operation (DVC only). The
fuses also provide voice-coil protection under transient conditions such
as accidental momentary overdrive. The fuses will not protect against
voice-coil failure resulting from long term high power abuse.
Justin89T
I Drive A Supra
Justin89T
The Third Island of China
406er
