45js45 10+ year member
Ok,there has to be some sort of guideline as to how many watts can be pushed a given fuse.Is there a conversion table?
You just have to understand how it works. A fuse has an amp rating meaning it is designed to only allow up to this amount of current to pass through before it blows. We use slow blowing fuses so they will allow over twice the amount of current to pass for a considerable amount of time before they blow so you cannot use this as a definitive guide as others will tell you BUT, Voltage x current(amps) / efficiency = power(watts)Ok,there has to be some sort of guideline as to how many watts can be pushed a given fuse.Is there a conversion table?
I thought AP either meant "Any Power?" or "Always Protect". Absolutely powerless. almost pioneer. audio poorly. absentminded purchase.ap 1500 comes with a 100anl fuse so that does what then on a 12volt setup?
very trueIt's also good to note that amplifier's efficiency changes depending on the impedence. The lower the impedence, the less efficient the amplifier becomes.
mehI thought AP either meant "Any Power?" or "Always Protect". Absolutely powerless. almost pioneer. audio poorly. absentminded purchase.
lulzlike most amplifiers the audiopipes only draw 5 amps of current at maximum output given 14.4v input.. But that same fuse can sustain 1000 amps of draw once your voltage drops below 10v.... Just ask sicaudio...
basically you have a 12 volt car so here is simple math using a 30 amp fuse:
12 volts * 30 amps = 360 watts. most amps are around 80% efficient so multiply the 360 like this..
360* .80 = 288 watts rms...
it is only a general guideline tho
but if you see an amp that says 2000 watts but it only has 100 amps of fuse you know it is a bs story...
where does it say that?Like most amplifiers the Audiopipes only draw 5 amps of current at maximum output given 14.4V input.. but that same fuse can sustain 1000 amps of draw once your voltage drops below 10V.... just ask SicAudio...
