Fuse problem
Dwayne614
I have a single kicker CVX 12 In a ported box with a 1200watt SPL amplifier, every time I bridge my amp my fuse goes bad, it DOESNT blow but when I test the continuity of the fuse there is none. I've been buying 60amp AGU fuses from o'reillys and I've been threw 5-6 fuses already
P.S. I don't blast my music to the point it distorts I don't even turn it up that loud and yes I'm very aware I have a cheap Chinese amp, Idgaf
what impedance is your sub??
If there is no continuity in the fuse... I'm pretty sure it blew. Especially if switching the fuse solves the problem.
I don't know the figures on your amp, but you may need a slightly larger fuse (like 100 amp or something)
I think Boomsday may be wondering if you ran your amp at too low of an impedance. Even if you don't turn it up all the way, the amp can still draw enough current to blow a fuse
Dwayne614
Dwayne614
Columbus, OH
adulbrich
