Fuse Manufacturer Differences
babendums
Can anyone explain the reason why different brand fuses of the same amp rating have vastly different element sizes?
For example my Skar 250a anl fuse has a way bigger element than my xs power 350a or even 400a spartan ceramic.
how accurate are these ratings? I'm starting to get into the 8-10k range so I definitely don't want a bottleneck in my electrical and want to stay safe also. Who has known accurate fuse ratings?
Different metals have different melting points. So you can have different size elements for the same blow point.
That being said, their are some cheap no name fuses floating around on the net that are rated completely wrong. I believe that every fuse these companies sell are all the same size fuse, just with different numbers printed on them. Buyer beware.
any thoughts on the skar fuses? they have huge elements, and they are a dollar a piece. They are different size elements between their rates fuses though.
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
585
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
Sounds like a bad ground or wiring problem on the 12v+ side.
13
babendums
babendums
Houston, TX
babendums
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
