fuse holder and wires getting hott
  • 4
I had a similar problem happening in my first ever audio build! I replaced my small 8AWG wire with a 4AWG wire and got matching fuses for the wire. Poof, never happened again.
had problem with 3 installs
example 1) 4awg 12+, (under passenger seat)mids amp 300 watt punch 8awg(power n ground), db drive 1500.1 4awg(power and ground), 2.6F capacitor. using distribution block 4awg also
---------- Post added at 08:04 PM ---------- Previous post was at 08:03 PM ----------
150a midi fuse, highs amp 40a, bass amp 80a
It was a powered 12 inch subwoofer. I don’t remember the exact one. It has been a while.
76
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
621
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
kapo4238
kapo4238
Miami, FL
m.doza
    May 18, 2024
    May 16, 2024
