boominbass 10+ year member
ALRITE GUYS..I JUS PURCHASED A BRAND NEW MTX 81000D AND IM AM STARTING TO WORRY, ONCE I OPENED THE BOX I SAW THE HARDPLY PAPER W/ THE AMP REQUIREMENTS WHICH ARE A 150AMP FUSE AND 1/0 AWG WIRE. i KNEW THAT THIS WOULD DRAIN MY BATTERY AND MY STOCK 94 BMW 325I ALT - WHICH I THINK PUTS OUT 80AMPS. i CALLED THIS GUY UP AT CARTRONICS AUDIO STORE AND HE SAID THAT I CAN RUN 4 AWG WIRE W/ AN 80 AMP FUSE AND THERE WOULD BE NO PROBLEM . IS THIS TRU? THEN AGAIN POWER WOULD BE AN ISSUE. WITH WHAT MTX SAYS @ 2 OHMS AT @VOLTS - I SHOULD GET 1200 WATTS ON THE 150AMP FUSE AND 0/1 AWG WIRE SET UP. WILL I GET THE SAME POWER RATINGS W? THE 4 AWG WIRE AND 80 AMP FUSE??? HELP. i HAVENT TAKEN THE AMP OUT OF THE SEALED PLASTIC YET SO I HAVE TIME TO SELL IT TO GET ANOTHER AMP. P.S. I WAS USING THIS AMP TO RUN 2 DVC 12" KICKER SOLOBARIC L5'S WHICH ARE NOT PURCHASED YET..HELLLP[PPPP!!!
