Sold FS:MTX LSX2 crossover MINT!!!
gtpzach51
I got a Mtx lsx2 crossover for sale...its in mint condition...barely used...have no use for this now...use this two connect two amps so that the same signal is sent...cost is $160 brand new online...looking to get half of that shipped...let me know if you have any questions.
Engineered for design efficiency for any system
The Crossovers make sure you direct the correct signal to the correct speaker so you don't lose any sound quality in the treble, mid-range and bass frequencies.
LSX2 Features
* 2-channel, 3-way or 4-channel, 2-way
* Dual high pass outputs with multiplier switch (front continuously adjustable on a scale of 30-400Hz or 600-8000Hz; Rear continuously variable from 30-400Hz)
* Low pass continuously variable from 20-200Hz
* Front and rear speaker level inputs
* Phase reversal switch (180°)
* Up to 8 volt RMS input signal for integration with high voltage output source units
* 18dB/octave slope for greater protection of mid-ranges and tweeters
* Continuously adjustable crossover points
* Wire harnesses for speaker level input allow easier integration with OEM systems
* 1 Meg Ohm Isolation maintained between the Signal Ground and Power Supply Ground (eliminates ground loop noise)
* External Bass Control (EBC) port connects to optional, dash-mountable EBC unit
$70 shipped take this...these are going for $75-100 on e-bay and that is with this shipping...and mine is in mint condition with barely any use...need to sell for car insurance
gtpzach51
gtpzach51
Mazeppa, MN
gtpzach51
michigan born
    May 14, 2026
michigan born
    May 14, 2026
