FS/FT Rockford Fosgate Punch 501x 4 channel Amplifier
Rockford Fosgate Punch 501x 4 Channel Amplifier
UPDATE: At this point I'm just looking to sell this amp rather than trade.
10/10 mechanical
9.5 cosmetic
65 watts RMS x 4 at 4 ohms
125 watts RMS x 4 at 2 ohms
250 watts RMS x 2 at 4 ohms in bridged mode
2-, 3-, or 4-channel output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
front and rear switchable high-pass (120 Hz, 12 dB/octave) and low-pass (80 Hz, 12 dB/octave) crossovers
MOSFET power supply and output devices
Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
preamp outputs
12-1/16"W x 2-3/8"H x 9-7/8"D
$180 obo (I'm looking to get a 2 channel amp in the 65-80w RMS range to drive rear components)
50/50 on shipping cost
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
MkVwGuy
MkVwGuy
Magnolia, DE
MkVwGuy
    May 24, 2024
