Djpac 10+ year member
ok, redoing this thread because other one got deleted... hopefully i did it right this time
But im selling my car stereo to get money to help pay for my new car!
AudioQue HD315 15" Subwoofer - $300
Specs:
Displacement: 0.23
Fs: 29
Qts: 0.33
Qes: 0.36
Qms: 3.96
Vas: 135
Le mH: 1.1
Sensitivity: 92dB
Magnet Weight: 330 oz
Circle Cut-out: 14"
1000-2500wRMS (max Unknown)
SoundStream PCA-1500D Amplifier - $320
* RMS @ 4 Ohms 800x1
* RMS @ 2 Ohms 1100x1
* RMS @ 1 Ohm 1500x1
* T.H.D.: 0.5%
* FREQ. RESPONSE (Hz): 5 - 250Hz
* SIGNAL TO NOISE RATIO: >80dB
* DAMPING FACTOR: >200
* INPUT SENSITVITY: 0.5-4.0V
* CROSSOVER SLOPES: 24dB
* INPUT SENSITVITY: 200mV
* CROSSOVER FREQUENCIES: High-Pass (Hz) N/A
* LOW PASS (Hz) N/A 55-220 55-220
* SUBWOOFER EQ: N/A N/A N/A
* SUBWOFFER EQ (HZ): 30-150 30-150 30-150
* DIMENSIONS (INCHES): 9.5x2.5x12.75 9.5x2.5x15.0 9.5
* Fully regulated MOSFET power supplies
* PWM circuitry
* Tri-guard amplifier protection
* IDI™ (Intelligent Distress Indicator) gives a visual indication of the amplifiers protection status
* Platinum RCA inputs and outputs
* TST™ (Twin Stack Technology) Allows 2 amplifiers to drive 1 voice coil,
* effectively doubling the power
* High quality FR-4 circuit board
* Class D circuitry
* Continuously variable low-pass crossover
* Continuously variable subsonic filter
Variable subwoofer equalizer
Platinum 2-gauge power connectors
Source voltage 11 - 16 volts DC
1-ohm stability
Includes EGA-RM Remote Bass Boost Control
Clarion DRX6475 Head Unit - $130
160W (40W x 4)
Disc/Tuner Title Memory
Touch-n-Go Fold Down Face
Multi-Color Display
Zero-Bit Detector Mute Circuit
4V HVO Line Level Output
2 PreOuts
Alpine MRH-F254 Amplifier - $70
Output Power at 14.4V (20Hz ~ 20kHz):
4 x 25W @ 4 ohm (0.08% THD)
4 x 35W @ 2 ohm (0.3% THD)
2 x 70W @ 4 ohm bridged (0.3% THD)
Freq. Response: 10Hz ~ 50kHz (+0/-1 dB)
S/N Ratio: 100 dBA
Fuse: 20A
Dimensions: 9" x 8.9" x 1.4" (23cm x 22.6cm x 3.6cm)
Weight: 5.7 lb. (2.6 kg.)
EFX HDX67 Convertible Speakers - $100
300 Watts Max. Peak Power
100 Watts RMS Power Handling
4 ohm Impendence
Frequency Response: 35Hz~25kHz
Woven Glass Fiber Woofer Cone
Rubber Surround
Black Tough Coat Crinkle Finish Painted Basket
Silk Soft Dome Swivel Mount Tweeter
Tweeter Flush Mount & Surface Mount Kits Included
2-Way 12dB/oct Passive Crossover Included
Multi Fit Adapter Mounting Plate Included.
Mounting:
Depth: 2 1/8”
Cut Out Size: 5”
*All items can be found on eBay*
Thanks!
Specs:
Displacement: 0.23
Fs: 29
Qts: 0.33
Qes: 0.36
Qms: 3.96
Vas: 135
Le mH: 1.1
Sensitivity: 92dB
Circle Cut-out: 14"
* T.H.D.: 0.5%
* PWM circuitry
* Class D circuitry
1-ohm stability
160W (40W x 4)
Multi-Color Display
2 PreOuts
S/N Ratio: 100 dBA
Fuse: 20A
4 ohm Impendence
Rubber Surround
Mounting:
Depth: 2 1/8”
Cut Out Size: 5”
Thanks!
