SOLD FS: Car Stereo
Djpac
ok, redoing this thread because other one got deleted... hopefully i did it right this time
But im selling my car stereo to get money to help pay for my new car!
AudioQue HD315 15" Subwoofer - $300
Specs:
Displacement: 0.23
Fs: 29
Qts: 0.33
Qes: 0.36
Qms: 3.96
Vas: 135
Le mH: 1.1
Sensitivity: 92dB
Magnet Weight: 330 oz
Circle Cut-out: 14"
1000-2500wRMS (max Unknown)
SoundStream PCA-1500D Amplifier - $320
* RMS @ 4 Ohms 800x1
* RMS @ 2 Ohms 1100x1
* RMS @ 1 Ohm 1500x1
* T.H.D.: 0.5%
* FREQ. RESPONSE (Hz): 5 - 250Hz
* SIGNAL TO NOISE RATIO: >80dB
* DAMPING FACTOR: >200
* INPUT SENSITVITY: 0.5-4.0V
* CROSSOVER SLOPES: 24dB
* INPUT SENSITVITY: 200mV
* CROSSOVER FREQUENCIES: High-Pass (Hz) N/A
* LOW PASS (Hz) N/A 55-220 55-220
* SUBWOOFER EQ: N/A N/A N/A
* SUBWOFFER EQ (HZ): 30-150 30-150 30-150
* DIMENSIONS (INCHES): 9.5x2.5x12.75 9.5x2.5x15.0 9.5
* Fully regulated MOSFET power supplies
* PWM circuitry
* Tri-guard amplifier protection
* IDI™ (Intelligent Distress Indicator) gives a visual indication of the amplifiers protection status
* Platinum RCA inputs and outputs
* TST™ (Twin Stack Technology) Allows 2 amplifiers to drive 1 voice coil,
* effectively doubling the power
* High quality FR-4 circuit board
* Class D circuitry
* Continuously variable low-pass crossover
* Continuously variable subsonic filter
Variable subwoofer equalizer
Platinum 2-gauge power connectors
Source voltage 11 - 16 volts DC
1-ohm stability
Includes EGA-RM Remote Bass Boost Control
Clarion DRX6475 Head Unit - $130
160W (40W x 4)
Disc/Tuner Title Memory
Touch-n-Go Fold Down Face
Multi-Color Display
Zero-Bit Detector Mute Circuit
4V HVO Line Level Output
2 PreOuts
Alpine MRH-F254 Amplifier - $70
Output Power at 14.4V (20Hz ~ 20kHz):
4 x 25W @ 4 ohm (0.08% THD)
4 x 35W @ 2 ohm (0.3% THD)
2 x 70W @ 4 ohm bridged (0.3% THD)
Freq. Response: 10Hz ~ 50kHz (+0/-1 dB)
S/N Ratio: 100 dBA
Fuse: 20A
Dimensions: 9" x 8.9" x 1.4" (23cm x 22.6cm x 3.6cm)
Weight: 5.7 lb. (2.6 kg.)
EFX HDX67 Convertible Speakers - $100
300 Watts Max. Peak Power
100 Watts RMS Power Handling
4 ohm Impendence
Frequency Response: 35Hz~25kHz
Woven Glass Fiber Woofer Cone
Rubber Surround
Black Tough Coat Crinkle Finish Painted Basket
Silk Soft Dome Swivel Mount Tweeter
Tweeter Flush Mount & Surface Mount Kits Included
2-Way 12dB/oct Passive Crossover Included
Multi Fit Adapter Mounting Plate Included.
Mounting:
Depth: 2 1/8”
Cut Out Size: 5”
*All items can be found on eBay*
Thanks!
You can go to theyre Website and check it out/do some research on your own, or even give them a call
33
7K
It should be called the accessory wire...it should be connected so that it only see power when the car is on...if its connected to constant power...
948
Unless Android made some big changes to their core program, it should work just fine. Just like using a 4g phone on 5g sevice.
If the original plugs have been cut off, you may want to get some from a wrecked car. You could also search online for a radio pin-out for said model.
Djpac
Djpac
Rhode Island
jaboran
