FS: 99 Explorer loaded with 10 15's in a wall
46panel
Michigan
Product:
Selling my 99 5.0 XLT AWD Explorer. It has 161,xxx miles and runs great. It's my daily driver.
Custom black paintjob with a blue flake throughout
New headlight assemblies /with HIDS
Tinted windows 5% on all back windows 35% front two
Added leaf springs in the rear to help with the weight of the system and level it out
22" chrome rims (will come with stock rims and tires if wanted)
10 15" Obsidian Audio subwoofers built into a wall covered in black carbon fiber looking vinyl.
5 American Bass 120.1 amplifiers (2,000 watts each)
DC Power 250 amp high output alternator
5 batteries plus the one under the hood
Mb quart discuss 4 channel
(6) 6.5" speakers, (4) 3.5" speakers built into the a pillars, (4) super tweeters
Price: :
7750 obo
Might be interested in trading for a different car.
Pictures:
[video=youtube;IX-8xN93RwI]
I was actually gonna ask you if you knew anyone lol. I have family in Minnesota though. Where in Michigan are you?
Was going to ask me if I knew anyone about what? And I'm basically where the upper and lower peninsula connect. Right by the bridge.
If you knew anything about getting it trailered down here,
I see, how far from Duluth Mn?
I don't know much about it, but I'm sure it would just consist of looking around at shipping companies and putting in zip codes from here to there and find out the best price. A quick search says about 8 hours from Duluth to Cheboygan. Probably less than that because they always are high it seems. It would basically just be a drive from one side of the upper peninsula to the other.
Okay I gotcha. Well would you consider selling with without all the amps? I mean I want everything else that's already in the truck I'd rather just use my sundown amps. Just a personal preference.
Subs there is no way I'd take out. Amps would be easier to uninstall so I might consider it but I'd really rather not. And if you went with something other than 5 amps you would have to completely rewire it.
Yeah I know I would want the subs to stay.
And yeah I know it would have to be rewired. Would **** lol
Hmm, quite interested. I might take it off your hands with cash. I'll be in Ironwood, MI in a couple days or about one week so...
Or, if you wanted, say a strappable pair with all strapping gear, one month old OPTIDRIVE 2601Ds. One is BNIB, one has been running two ol' 10W6s @4ohm for my SQ comp car, so, FAR from any high current has passed through either of them. Yes, OPTIs for SQ, LOL, but hey, it's the low end stage so if I put a better quality amplifier in there, it'd make no difference to the ear I'm sure, perhaps only an RTA would know a slight change :p
Or say a matching set of all DEI American made Orion amplifiers. Orion 3002, 4002, and 2500D (I ran them active in SQ comps before, and for SPL comps with them as well in MECa and MWSPL; I'd just wire up or wire down and change a setting on the EQ :p) which clamped 3.3kW at .4ohm nominal with voltage dropping from 14.5V to 12.4V. I beefed it up so it would not be subject to vibration damage as a lot of people talk about with the 2500Ds.
Any other equipment you might me after? Like say $6k plus some equipment for the other wheel/tire combination? Or perhaps just $6k for the truck with the stockers on it and not the 22" wheels? I have a STUPID amount of equipment, like tons of quality 1/0, install accessories, 17 batteries, 27 amplifiers (a few more high powered Class Ds) and mostly older American Made cheater and SQ amplifiers, lots of motors, baskets, woofers, a couple EQs, et cetera et cetera lol. I easily have $7k+ worth of equipment for LMK buddy!
Also, what are the six batteries you have in the truck? Have you clamped any amplifiers to see how close to the 2kW ratings you are? Or do you think you actually might be near a true 10kWrms? And is the enclosure a sealed set of QTY10 15" drivers, or were you after a 4th order BP with it buddy? Perhaps enclosure specs would be nice brother, or I'll look for that build log to see how well and solid that SUCKER IS!
Well hey thanks a lot buddy,
Ron
Lol yea.
Hmm, quite interested. I might take it off your hands with cash. I'll be in Ironwood, MI in a couple days or about one week so...Or, if you wanted, say a strappable pair with all strapping gear, one month old OPTIDRIVE 2601Ds. One is BNIB, one has been running two ol' 10W6s @4ohm for my SQ comp car, so, FAR from any high current has passed through either of them. Yes, OPTIs for SQ, LOL, but hey, it's the low end stage so if I put a better quality amplifier in there, it'd make no difference to the ear I'm sure, perhaps only an RTA would know a slight change :p
Also, what are the six batteries you have in the truck? Have you clamped any amplifiers to see how close to the 2kW ratings you are? And is the enclosure a sealed set of QTY10 15" drivers, or were you after a 4th order BP with it buddy?
Ron
Well I would mainly be interested in the cash. I would take $6250 for it without the 22's. Or $7,000 with them. I might be interested in the orion 2500D to knock a little bit off.
The batteries are 5 c&d 100 or 102ah in the back (3 right below the amps 2 in front of the box). And the one under the hood is a big deep cycle. I haven't ever clamped the amps, but each amp starts at .5ohm so I'm sure its right around the 2k mark each. The box was designed to be a 1:1.5 ratio 4th order. 7.5 sealed each side so 15 total and 22 cubes ported. After I started putting the loading wall on I preferred it without so now its basically like two sealed boxes.
https://www.amazon.com/gp/product/B0016G4EXQ/?tag=caraudiocom-20 https://www.amazon.com/gp/product/B07BMT699G/?tag=caraudiocom-20 Im not a fan of...
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
885
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
46panel
46panel
Michigan
46panel
    May 18, 2024
    May 16, 2024
