Free Box designs.
2001 Nissan Maxima12" Fi Q w/ BP Power Option D2
Max External Dimensions
D X W X H
16" X 30" X 15"
Double Baffled
Tuned to 32Hz with single slot port
I would suggest around 2.25-2.5 cubes net with 28 square inches of port, but it looks to me like you need no suggestions. So please if you think you have a better idea, go with it.
Thanks in advance, anything is greatly appreciated
3.06^3 w/o port @ 32hz
hook me up with a large sealed enclouser for two tc-7 10's (not sure how many cubes to run that at)
then also a ported box with precision ports.
i have two 13'' long 3'' diamater ports for each sub. i was thinking something like 34long 15 high and 15deep
figure something out please.
2 12" memphis m3s 40"W x 18"H x 18.5"D tuned to 32hz center port. whats the donating rate these days?
thanks
Any donation is good! Whatever you think some of the 3d designs take about 30mins to 4hours.
6.256^3 w/o port at 32hz lots of port area!
2 pioneer 12" 5000spl , w 46 x h 17.5 x d ( up to 22 ) , sub would be mounted in the 17.5" section, tuned@35 seperate chamber for each sub if its possible
thanks alot
ps
using 1" mdf all around
each chamber is 3.85^3 @35hz 1" MDF
I need 3 designs please..... If possible.
I have 4 12" Eclipse SW7200 Series Subs...
.... First design will be (2) 12s Ported....
Max Dimension: 42"L x 14"H x 24"D
.... Design #2 is for (3) 12s Ported.....
Max Dimension: 41"L x 15"H x 24"D
..... Design #3 is for (4) 12s Ported.....
Max Dimensions: 36"L x 13"H x ??"D
( There is a 17"H x 22"L opening in the middle that leds into the cab... Use that for more airspace - Located dead center/middle of the trunk - My backseat stays down at all times )
Thanks in Advance!
How about...
Dayton RSS265HF-4 10" Sub
Sub must be in Down firing config, flush mounted....using a slot port that goes out the top (out one of the sides, doesn't matter)...
the actual box must be a 12" x 12" (picture a standing rectangle)... but the height can be as high as needed to fulfill the requirements of the box...
Tuned to 20hz....
edit; 3/4" MDF...will be used..
Your box gives me headaches on building it. Also designing it.
1.875^3 w/o port @ 20hz
Bottom
The design is still the same on the 1st page....
*waiting for you do re-image on the interntal slot dimensions*
Fi Q 15" Vented enclosure...
Donations will be sent, once i complete the enclosure!*
Me = ZZZZZZZZZZZzzzzz.... Need to work on my jetta tomorrow if it's not raining. I do some more boxes tomorrow don't worry =). Still no donations //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif:crap:
Just wanna make sure, all the cuts, i need the add .75"?Or its already added with the dimensions...
Width of the box is 34", the cut out is 34" 3/4....
All the sides are measured in 3/4 MDF 34" is the width =)
I always add the 3/4 measurements into the box design or 1" or 1/2" Depends on the person but i always do 3/4 unless the customer wants something different.
Hey rcnshoe your designs look rad.. could you make one with a double baffle for my 13W3v3-4?
Max dimensions are 14.5H x 28W x no more than like 27D
JL recommends 2.25^3 @ 27 hz, but the box on their site is too tall for my trunk (96 Nissan Maxima)
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif Come on guys he's doing all this great work for you and no ones given him any donations???
rcnshoe
VW Pimp
rcnshoe
Next to you.
roarzorz
