Ford Probe enclosure...
  • 2
Louisiana_CRX
dem shoes......
Getting ready to install my DD 9512G into this enclosure ..I may do a build log soon ..the amp will be a DB Drive PD 2000.1 ....
The very first stick shift car i drove was an 89 probe gt. Fun little car, handled very well too.
Mine is a 5spd Manual LX model the 2.2 was the only engine in 89 ..it currently has 86,000 miles on it ..I’d rather of found a nice low mileage GT but they are hard to find these days in first Gens...So I’ve been working with this one ..I’m getting ready to revamp my whole sound system in it ...but just getting the substage first
618
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
    May 19, 2024
    May 19, 2024
