Ford f150 05- bl18, sundown, hertz, big build
Thanks. Im going to run out before i get to the doors i think though do you know how much ill need for all 4 doors?
Plan on 15~ per door.
I did 22 per door of my durango, but that was double layers.
14-15 should cover each of your doors.
Sounds about right...I did around 18ft per door if I remember right. I didn't really go all out either, one layer in most spots, two in some.
HELP!!!
I tried turning my car on this morning and it wouldn't start. This thing started clicking so i had to unplug it. but if i plug it back in it starts clicking again. Does anyone know what to do?
HELP!!!
Thats the gig for your factory security system. Are you sure you have the two plugs in it correct (not swapped side for side)
Also does your keyfob work to lock/unlock your doors currently?
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
They really are. Fit to perfection! Sounds Good Stereo are the best.
671
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
helotr3vor
helotr3vor
Irvine, CA
helotr3vor
audiobaun
    May 19, 2024
    May 19, 2024
