Ford f150 05- bl18, sundown, hertz, big build
Very similar to what I was going to do.
I've got an 05 SuperCrew, I think we've talked before :)
I'm doing the same thing you are, except I'm doing an RD Heavyweight 15 in a 4th order //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Seat riser kit+ two nice 12's = pretty **** loud in that truck, and still able to sit in the back semi-comfy
Kenny(he's on the forums as jack something) has an F-150 with two single spider RD Alpha 12's on an RD 1750.1 and is doing a 45.xx legal on the dash with them. Sealed, under rear seat.
Good luck. I wont be doing my build(but I'll still get pictures so I can post a semi-log) and I cant afford new components yet so stockers will have to suffice for a while //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Look forward to seeing it bossman.
Yeah im pretty stoked but i need to learn how to do the wireing because im going to try and just do everything myself to get the learning experience and so i can get better at it
cant you cover everything exept like one hole and the door handle spot?
Look at the back of one of your door panels...there are a bunch of clips that go into the door frame and then slide down to lock the door panel in place. It ***** //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
You definately need to check one and see how it goes on before you start deadening em
edit...mines an 07 but wouldn't think they'd be that different
The wiring isnt that hard man, if you're worried about it meet up with someone from the forum that has a few minutes to walk through it with you.
And you need to be able to put all of the clips back in, ideally.
It has to clip into place and stay there or it does you absolutely no good
Whats the best thing to clean the plastic panels? mine got scuffed up
What clips are you talking about?
i got an 06 Extended cab.
1 18" RE MT and 1000 RMS right now with a 225 amp alt big three and 1/0 from front to back as well for the big three.
heres a little vid. the back window has some nice flex and i can do a lil hair trick with only 1000 watts. wait till the 4KW gets here //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
oh im tuned at 28 hz. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
There should be plastic clips on the back of the door, or something very similar to where the door "locks" back into place. There shoudl be holes in your door where the clips slide in, and then lock down into place.
When you get a chance, take a better look at the back of your door panels, as stated.
No idea what to suggest to help cleanup the scuffs. Unfortunately I think I've changed setup in my truck more times than I have cleaned it //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Hopefully the scuffs are light and the panels aren't too scratched up where its noticeable
Interested in this.
I'd like to see some pics of that install. Got a link to anything?
Yeah i hope. My truck would look funny if they were messed up then i would have 22"black rims with tint and a killer system but shity interior
looks sick. mines a 2 door so i got more room and i will still fit 2 seats in the back //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i took my back seats out because i dont like carting everyone and their mom around so i yanked them and am about to build my wall for 3 MT 18's.
yea, man your rims really set your truck off.
i cant afford any though //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Yeah im going to get smoked lights and tint soon so it will bring it out more. i was thinking about getting my bumpers painted black too just to have everything except the body paint job black
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
They really are. Fit to perfection! Sounds Good Stereo are the best.
512
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
helotr3vor
helotr3vor
Irvine, CA
helotr3vor
Brendon Jenness
    May 8, 2024
    May 8, 2024
