Floor Box??
  • 2
i3abyjay25
Get F'n Loud
how good are Floor boxes?? caus eim wanting to build a floor box for 4 12 and my Orion amp.. my trunk space is 38x36... most likely /ill build the box 38x 36 x 10 which should give each sub around 1.4 cubic volume, tha is if i did my math correctly..but also i still have to cut out room for the amp, which is 25 x 10.. so im not sure how to figure out the volume w/ this cut.. what do ya think would be the best size and best thing to do?
ok, i just re did my measuments and all.. ok the inside of the box measurment will be
36.5 x 34.5 x 8.5.. plug that into the formula... 36.5 x 34.5 x 8.5 x 0.00058 = 6.208, 6.208 / 4 is 1.55....so should be 1.55 sq ' but the total box size will end up being 38 x 36 x10 , if i use 3/4 inch plywood... if i use 1/2 plywood, then my measurments would change to 38x35x9 and that would change the box volume to 1.68 per sq '
Thanks for the comp!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have used that formula for quit a while and it has always done me good. I'm sure that they are others out there.
I would go with the 3/4" for the sake of it being more sturdy. I used the width and the depth as fixed #'s and adjusted the height according to the displacement on the amp box and subs.
Good luck!!
....Send me your e-mail and I will hook you up with a pretty cool conversion table.
trixprod@aol.com
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
772
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
7
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
367
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
602
i3abyjay25
Get F'n Loud
i3abyjay25
Dallas, Georgia
Trixter
winkychevelle
    May 24, 2024
