first post - do I have a problem here?
irolllow
Here is the situation and concerns regarding my mobile a/v system...
I have an Alpine IVA-W205 source unit. I am assuming that the built-in amplifier of this source unit is rated and designed to operate with speakers rated at an impedance of 4 ohms.
Running off of the head unit's built-in amplifier, I have a set of Infinity Kappa 6 x 9coaxial speakers in the rear of the car and a set of Infinity Reference 2-way components in the front of the car. When I bought and installed these speakers I did not know that they were all rated at a 2-ohm impedance. However, I have read reviews and whatnot that state that the Infinity speakers ( though rated at 2 ohms ) actually have an impedance closer to 4 ohms due to Infinity's " true 4 ohm " technology or something like that. Is this true?
Assuming that the Infinity speakers have an actual impedance of 2 ohms, am I potentially damaging the built-in amplifier of my source unit by running 2-ohm loads off of each channel?
If I am potentially damaging the source unit's built-in amplifier, I am know that I can solve this problem by simply buying and installing an external amplifier to power the speakers ( as long as the amplifier is stable at 2 ohm loads ). However, I am also concerned with the fact that running 2-ohm load speakers will decrease my system's sound quality as opposed to running 4-ohm load speakers. Did I mess up by buying these speakers?
I would try calling Alpine to see what the minimum ohm load on their HUs.
That is a good suggestion and I will definitely do that. Thanks a lot for the input.
However, I still need to know if the Infinity speakers are truly 2-ohm speakers or if their " true 4 ohm " technology makes it to where they are actually operating at a 4-ohm load though rated at 2-ohms.
Also, I would appreciate you guys' input on the last part of the question concerning the decrease of sound quality by running an external amplifier at 2 ohms.
It would be difficult to NOT get better sound from an external amp.
I understand that, but I think I may have asked the question in a confusing manner. Let me rephrase it...
Assuming that the Infinity speakers are actually 2-ohm speakers and I run them off of an external amplifier that is stable at 2 ohm loads, how much sound quality am I sacrificing in comparison to a setup of similar quality products that operates at 4 ohms?
Hopefully that makes more sense.
Zero.
If you have a digital multi-meter, then it would help you figure out the impedence of the speakers.
I have a basic knowledge of audio, but I am not a professional by any means ( or even close to it ). To be honest, all of the factors that influence electrical impedance would confuse me to the point that my actions would probably be useless without a more-experienced installer present.
Considering the fact that achieving the best sound quality that I can with the setup that I have is my main goal, that makes me feel better. I have no problem buying a couple of external two-channel amplifiers and an external signal processor if the impedance turns out to be an issue.
i don't know of many, if any, aftermarket HUs that do 2-ohm loads. Little chip amps and such won't take the abuse long.
I run a dead-head.
i don't know of many, if any, aftermarket HUs that do 2-ohm loads. Little chip amps and such won't take the abuse long.I run a dead-head.
After reading your statement, could it be reasonable for me to consider the fact that these speakers have been running off of my built-in Alpine head unit for a while now as an indicator that the speakers actually operate at 4 ohms as opposed to 2 ohms?
From what you posted, I am left with the assumption that this system would not be operating properly if the speakers were actually 2-ohm speakers.
irolllow
irolllow
Walla Walla, WA
BurnOne
michigan born
    May 14, 2026
michigan born
    May 14, 2026
