first box build
  • 2
crakerhead
hey all i'm building my first ported box. it's for a dd 9515. i got dimensions from dd themself. here they are :20" Deep, 15" Tall, 34" Wide. I'm not sure what the dimensions of the port will be. I need help on how to place the port wood inside of box. I'm making out of 3/4 mdf btw. When I go to place to get wood what dimensions should I cut the wood into? And what should the dimensions of the port wood be? Can you'll post pics boxes' inside. This way I can get an idea of what goes where and all. Thanks a lot everyone!
it's all going in the back of a 1990 audi 80 sub will be powered by jbl 1200 at one ohm. dd says this is supposed to be a 4 cubic ft box. they didn't say what to tune it to though. but if you have dimensions for a 3 cubic ft box that would be great too to save some space b/c as of now i have no room what so ever. I'd actually rather a 3 cft box so it can actually move some air in the trunk.
If your asking how big the port should be then you have opened a can of worms. It depends on what freq. you want the box porrted at. I can tell you that if your port was 3" wide the you should keep it at least 3" off the sides and bottom of your enclosure.
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
Love this sub, hate AB's site, short on info for sure. American Bass XR-10D2 box recomend: If you want to tune a 2.75 Cu Ft box (for two of these...
crakerhead
crakerhead
Richmond, VA
crakerhead
