Finding/splitting a 12v supply to power Tablet
  • 6
che47audio
UK
Hi there,
I recently started to install a Nexus 7 to be used as a head unit in my car. I have it fitted and looking nice with the line output running to the aux input of my car stereo which is now mounted in the glove box. Now I just need to power it!!
So my questions are,
- can I split the 12v that currently feeds the ISO connector to the stereo and use an adapter to get the 5v 2a that I need? Or is this dangerous?
- It would make sense to use the "switched" 12v volts so the tablet is only powered when the ignition is on. Agree?
- If I can't use the twelve volts that is currently powering the car stereo at the same time, where can I get power from?
Thanks for your time
Most appreicated
Chris
Good shout. I was just thinking I would make sense if the tablet was only getting power whilst the engine was running. I can set the tablet to sleep when there is no power and wake when it sees ac power. So if I hard wired it, it would wake/sleep when the ignition was on/off. Otherwise I have to unplug it every time I leave the car.
Thoughts? I should have probably mentioned that this tablet is permanently mounted in the dash.
Cheers
Yep. It is.
Does anyone here know if its ok to take the 12 volts from the stereo harness? It would be sharing that 12volts with the Sony head unit that I am using for the aux input and probably radio.
Thanks again
Thanks for your responses. Please could you explain in more detail the points at which you soldered on to the usb charger as this is what I plan to do . And tapped the power at the deck. What does that mean? This may be easier than I had orignally thought! Exciting!
Cheers
picture the cig lighter plug car charger. on the tip is the + contact and on both sides of it are the - contacts. I just solder wires to those contacts and connect them to power and ground. you will have to find a switched 12v but you can find ground pretty much everywhere there is metal in those vehicles.
1. You need to feed that USB plug that goes into your tablet 5V not 12V
2. Use a cigarette lighter to USB plug adapter like mentioned previously to knock you 12V feed down to 5V for your USB cable into the tablet.
3. If you want to hide everything just use a female 12V cigarette lighter adapter that terminates into bare wires or get one with a trailer plug or something and cut the end off and wire it into the 12V Switched and Ground of the harness for your stereo.
Like this
Hook one of these into your 12V switched and Ground on the stereo harness
Then hide it behind the dash and plug one of these into it
Now plug your tablet usb cable into the USB adapter and heat shrink the connection.
Voila
12V to 5V USB rail hidden behind dash and the lead is only charging or hot in key position 2.
But keep in mind just because the car is off it wont turn your tablet off it just wont charge. You will still have to power down you device manually for a full off or just let it go to sleep.
Hope this helps. I have hooked up tons of A/V retrofits into OEM screens/Navi head units in my BMW's this way.
Hey, I have golf 2019. I have audison voce and want another speakers in front, and the Audison move to the back I have thought about those- Focal...
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
Stop bumping old threads. @Popwarhomie has his enough to do today without this ****.
43
6K
Thanks a lot. iPhone charging. Wow. No cigarette lighters now.
35
6K
che47audio
che47audio
UK
Lexicon740iL
    May 22, 2024
    May 22, 2024
