Finally....My new install build
Awesome, wish I could hear it. How does it sound when sitting in the car with the doors closed? Does the closeness of the drivers side tweeter make it stand out too much? How is the staging?
the staging is awsome...
the X-over also has a few tweeter adjustments on it
with the way it is set up the sound swallows you up...
it is very full and clear as a bell and really friggin loud...
even standing 100 feet away from the car you can hear
how crisp and tight it is..
I am very impressed....
I have a set of CDT .07x3 components and they do not even
come close to these things...I have them up for grabs...
if anyone is interested.... $900 canadian
if I don't sell them I will probably stick them in the wifes car
with a single 8" sub..it would be more than enough for her
the PX 600.2 amp puts out 180w rms x 2 into 4 ohm
and 290w rms x 2 into 2 ohm
with a single PX 600.2 each set would receive
145w rms per set and because of the lower
ohm load (2 ohm) the signal to noise ratio will
also be lower
with a PX 600.2 amp per set of components each
set will get 180w rms x 2 at 4 ohm with the highest
signal to noise ratio possible...
the damping factor of the PX 600.2 amp is also higher
at a 4 ohm load than it would be at a 2 ohm load
(better mid bass control)
bottom line each channel will get more power and
slightly better sound quality
the PX 600.2 amp puts out 180w rms x 2 into 4 ohmand 290w rms x 2 into 2 ohm
also be lower
ok.
I could guess that.
how much is the damping factor of it?
The power series amps have a very high "effective damping factor"
here are the specks
CEA Rated
Power Output 180 watts RMS x 2 channels at 4 ohms
and ≤ 1% THD + N
290 watts RMS x 2 channels at 2 ohms,
14.4 V supply and ≤ 1% THD + N
Signal-to-Noise Ratio 79.5 dBA (reference 1 watt into 4 ohms)
Dynamic Power 714 watts at 4 ohms
Effective Damping Factor 6.274 at 4 ohms
Maximum Input Signal 5.95 V
Frequency Response 10Hz – 97kHz (-3dB)
Maximum Sensitivity 264 mV
Output Regulation .056 db at 4 ohms
Dimensions (H x W x D) 2-9/16" x 17" x 12-1/4"
I had a tough time trying to find a place for those
gigantic X-overs...
this is what I did to them... they are countersunk into
the the racks and bolted on solid
I am also working on the pods for the tweeters....
the placement in the doors is only temporary...
the tweeters are going into the pillars
THUMPPER
Pound That Sound
THUMPPER
Salmon Arm BC Canada
THUMPPER
Mike Mccabe
