FI questions NEED ANSWERS! quick
the main question here is what type of trunk is it? is it a small trunk or a large trunk?
you can fit 2 15's sealed in most trunks. now, as for porting 2 15's in your average size trunk may be an issue and may cause you to have to reduce the amount of airspace available for the enclosure itself. that itself will not be good if you can't reach the recommended enclosure specs.
also, with the large amount of air space required for ported enclosure you may end up having to build it in the trunk.
if you're just going to loudness with ease of installation just get yourself a single btl 15" and run it off w/e power you were planning to feed to the BL's. it will be more than enough in a trunk car.
truthfully, 2 15's will make alot of panel/trunk rattle no matter how well you deaden it.
oh it's an intrepid?
go 2 15's then.
you should get Q's if you say a BTL is more of a comp sub if run single compared to 2 BLs.. i run a 15BTL on 3k daily.. it could use more sound quality but srsly not a horrible sounding speaker. and if your weary about the sound quality of a btl i'd be weary about the sound quality of a BL, as they are slightly more geared towards SPL than the Q. iirc, they are basically the same speaker too.
ABNgang
ABNgang
Carmel,Indiana
NDMstang65
NorthFramingham
    Jun 30, 2026
