fi q sealed or ported
I wouldn't go ported unless you can build a decent size enclosure for it. I tried to squeeze my Fi Q 15 into just over 3 cubes ported tuned to 35 hz and it seems very peaky and although it goes low it doesn't hit the lows with the authority you would expect. I have been throwing around the idea of going sealed just to save some space in my trunk. I rarely jam it full tilt these days anyhow.
for the best quality its sealed. this is more of a sql type driver. its made to sound pretty good but still get down when you want it to. thats why the fi q 18 works great in only 4.4 cubes sealed. get loud and stupid low and keeps nice SQ....for sheer (sp? shear?) output id go with ported but honestly id go with a different sub all together
alrighty i think ill be going sealed for now but i might try ported later on.
do you think that the Sundown Audio SAZ-1000D is a match for the sub or should i go for the Sundown Audio SAZ-1500D?
thanks.
I preferred it sealed, but I'm not a basshead...
I think you'd be fine with the 1000D...
Go sealed, and I think you'd like the results.
I'll post my question here rather than starting another topic.
My old setup was 2 12" RE Se in 4 cft @ 33hz.
Would a 18" FI Q sealed in 5 cft be:
1. louder?
2. lower?
3. sound better?
4. work okay for occasional metal listening?
Thanks
I run a 15" Q in the wife's car, 3.2cubes @ 32Hz and off an SD1500. Sounds good and hits the lows very well for. Took some EQ'ing to clean up the bottom end as it could be boomy at times...
yeahtoaster
yeahtoaster
wausau, wi
mlstrass
