fawd06 build 2-15"sx PICS
WIthout the backseat, You could build a amp rack behind the box that is in the rear seat area that would fit the IA 20.1 and some HC2400's depending how you do it. 33" Wide. I'm going to have to re-measure....
I am building it this weekend maybe. But here's a layout of the amprack.
I'm still not sure how you fit 30"+ Width. I measured like twice and it was like 29" width. Which section did you measure? I measured right inbetween the plastic panels. 15" looks really high. Does it go above the rear trunk top? Mines going to be able 14" high. If your measurements really work I'm thinking of re-do'ing the measurements. The pic above is how my new setups going to be. The HC2400's will be in the box section where the amp's are going to be mounted.
well for a fact u can get 32 wide and the box still moves a lil bit!! ill go with 32 to be on the safe side!!! do u have your aamp rack yet?
How much room do you have left from the port to the rear of the trunk? Can I get a picture of the trunk closed to see how high it is? It's not above the window seal is it? What years the car? 94-97 or 98-01?
fawd06
fawd06
Marrero, LA
fawd06
    Jun 20, 2026
    Jun 20, 2026
