I have to give up(again) my Kenwood crossover. This is an Audiophile piece that has tons of features and inputs/outputs. You can configure this thing almost anyway you need. Great shape and comes with the manual as well. Email me for pics, i will try and get some up by tonight. Really need to sell, but i don't have a crack problem so no lowballers please, this went for $400+ when it was new
Let me know if there are any specs needed and i will get them and pics up soon.
Price$$$$$$$$4Looking for offers, i know people hate that, but lets try at least $100..........
Here are some specs
6-Way Electronic Crossover Network
Front Mid: LPF(800 Hz - 10 kHz), HPF(30 Hz - 800 Hz), Level(Off - 0 dB), On/Through Switch
Front High: HPF(800 Hz - 10 kHz), Level(Off - 0 dB), Phase Switch(180°)
Rear Mid: LPF(800 Hz - 10 kHz), HPF(30 Hz - 800 Hz), Level(Off - 0 dB), On/Through Switch
Rear High: HPF(800 Hz - 10 kHz), Level(Off - 0 dB), Phase Switch(180°)
Low 1:Operation Switch (Rear, F+R, AUX), LPF(30 Hz - 800 Hz), Level(0 - +10 dB), Phase Switch (180°), Mono/Stereo Switch
Low 2:Operation Switch(Front, Rear, F+R), LPF(120 Hz - 800 Hz), Subsonic(30 Hz - 120 Hz), Level(Off - 0 dB), Phase Switch(180°), Mono/Stereo Switch
Parametric EQ: Low1/Low2 Switch, Freq. Control(30 - 300 Hz), Level Control(-10 - +10 dB)
RCA Inputs: 3 Pair
RCA Outputs: 6 Pair
Acrylic Panel
Ground Screws for RCA Cables w/ Ground Wire
Signal to Noise Ratio: 100 dB
THD: 0.01%
Frequency Response: 20 Hz - 100 kHz
12 dB/Oct Crossovers(Mono Mode 18 dB/Oct)
3A Fuse
Dimensions: 11-1/5" W x 1-15/16" H x 7-7/8" D
Here are some specs
RCA Inputs: 3 Pair
RCA Outputs: 6 Pair
Acrylic Panel
THD: 0.01%
3A Fuse
