Everthing stopped working. . .
Civic_boi334
I made a right turn and and everything shut off. . . i checked all fuses,and also tried to power it up getting a small piece of wire touching the 12v to rem and all it did was spark, smoke and burn the wire. Does anyone know what this could be???//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
lol about the turns. i wanted to say go make a left turn then but that was covered.
well you may want to unhook everything on the amp and check your connections. to have your remote spark when yourjumping the amp is a little odd. it is possible that your amp shorted out.
if its your mids/highs in your doors, check for wires rubbing causing a short. thats what happened to me. left turn and the speaker in my door would go out. pulled the speaker and noticed two wires had some bare metal that would move around and touch cutting the speaker off. cut the bare spot in the wire out and its as good as new.
check all the speaker connection's. and allso trace the remote turn on wire.. make sure it's not grounded anywhere in the car or behind the deck..
Civic_boi334
Civic_boi334
Montgomery Al.
SethPhillips
