ok i guess ill just set everything to 0, use a 50hz test tune and see how it sounds. Now if i do that and it doesnt sound good to me, is it "dangerous" to mess with my EQs? (like putting my 8khz to +6) Should i turn back my gain a bit more then a hair after distortion level to leave room to mess with my EQ?
Another thing, if i use a 50Hz test tone and set my amps filter freq. at 60-63hz and my HU subwoofer setting at 80Hz, is that defeating the pourpose of using a 50Hz test tone?
Also do you know how to use the Ohm setting on DMMs? what can the Ohm setting do for me?
Thanks Moble Enclosurs, really helping me out here.
That is a good idea. It can be dangerous, yes. The best bet is to get drivers that have good sensitivity for the frequency range. For instance, if your mids do not hold up with the tweeters, then instead of boosting the mid frequencies, either lower the gains on the tweeters or get higher sensitive mids.
Now regarding the gain, yea, setting it back a bit can help. A lot of people will recommend this, and is a great idea.
Ok. the filters from both the HU and the EQ are going to help each other. The best best is to set the HU at the highest filter cutoff that it can use for the sub, or not even use it if that is an option so the HU gives the amp and EQ the full band to play with, then use the amp filter to set it. But what will happen if you set the HU at 80 and then the amp at a lower filter, then the 80Hz filter will have a much higher rolloff than needed to blend in with the mids correctly. So, if you cannot get rid of the HU filter, then the best best is to let it control the filter, and set the amp filter higher than 80hz so it does not interfere with the slope drop off AT 80hz as much. But no, that does not defeat the tone, just will increase the cutoff more rapidly, and when that is adjusted further, it may be very very sensitive to any minor changes after it is tuned.
Now, with the DMM, the ohms settings is based on resistance. This is helpful in figuring for an unknown resistance of the overall circuit. You can verify the resistance of the drivers when loaded, and figure or find for other factors such as current, power, and voltage, which can then in turn be used to find other factors of a circuit, such as impedance matching, current load, voltage drop, and other things to make sure your system is running properly and connected properly. Most if the time I use resistance is for verifying and fixing problems with a loss on the load or verifying load resistance to figure for output and impedance curves for tuning factors and such. But really because it is a DMM, the posibilities are virtually endless in audio.
