Enough port area?
  • 7
What's the most common method of port design in your typical "L" shaped box when the port is longer than the box allows?
Here's two different styles i've seen, (rough sketched this to show you what i'm talking about)
The second.
If I can get away with a 4inch round port that would be easier for sure...I just don't know if that would be adequate...I would rather error on the side of caution and have more than enough, than not enough. WINISD recommends 2.5cubes tuned at 23hz!
I really believe 4" round is plenty for 600W single 12. As you say going too big won't get you in as much trouble, at the same time you don't strike me as the type that is going to be even pushing your 600W much even so even if you were right on the edge of on-paper being inadequate I don't think you'd have any issue real-world 99% of the time. You need pretty high port velocity to get chuffing noise, flared ports can help with this and you need to displace the entire volume of air in the port before you break woofers which you absolutely will never do with a 12 spoke frame 12".
You want as few bends as possible when designing a slot port
Definitely this.
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
4K
NSTALN
Dismember
NSTALN
Manchester, NH
hispls
SPLBassJunkie
    May 21, 2024
    May 20, 2024
