xtremekustomz
I was actually being serious when I was asking the question about what I was wrong about. I'm hoping that you aren't thinking that I'm trying to start an argument or anything like that or being "arrogant". I'm just speaking from my personal experience with large door mounted midrange drivers. I talked to Scott B. at the beginning of the year when I started my build and told him about the problem I was having with my midbass in the door and about it playing up to 900hz. Here is the "conversation"That's a very good point. You can't expect world class sound and performance on 4th grade car audio education. Not saying that to be offensive, but put the information in the contex of the person using it!
I personally love to read what Scott B has to say because he doesn't beat around the bush and will translate what his ears and experience have taught him. But, he does it in a civil matter and doesn't go down the arrogant *** route. //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
Thanks Scott, I appreciate the prompt reply. I do have a
question for you. It isn't really on the subject of Hybrid Audio but I hope
you can help me out. I've got a 2000 Chevrolet Silverado truck. I have
the Dynaudio System 360 in it which consists of an 8" midbass (50
hz-900hz) 3" midrange (900hz-4500hz) and a 1.1" tweeter (4500hz up). I have
the midrange and the tweeter in the kick panel and the midbass in the
doors. My problem is that on certain things, my soundstage is pulled down
to even with the top of the door. I have been told that it is because
the frequency is too high on the midbass in the door and it tends to be
pulled down. I have a few options and wanted to know what you think
about it. I can either mount the midbass in the floor or either in the
kick panel. Doing the kick panel will require a little more work I think
because of the air space requirements.
Ah yes, that is in fact why you have a problem in the midrange
frequencies, it's because of the midbass location. Putting the midbass as
physically close as possible to the midrange will help immensely. If you
can even put them on the same plane as the midrange, even better. But if not,
get them close. Because of the dispersion pattern of the midbass, and at
the frequencies you're asking it to play, aiming is not super
critical, but is at the very least important. Everything below around 1,000 Hz is
time dominant, so getting them down there will help with imaging quite a bit.
I'd spend the extra time and get them angled just right in each kick panel,
verses in the floor, because a phenomenon might occur that the
images will wander left to right on male vocals if the midbass is in the
center of the floor...so as the male vocalist's pitch changes from high to
low, for example, his voice will wander between the two speakers. This is
precisely why we built a midrange that can play to 200 Hz rather eaily, so
placement of the midbass is not nearly as critical.
Scott
Well..I think I have decided to build a dash. I'm planning on
getting my old dash out within the next few weeks and seeing what room I
have to work with. I want to keep my ac and defroster because I will
still be driving the truck alot. In the case that I am building a new dash,
would I get better overall results from placing the speakers in the
dash? What I have been thinking about doing maybe is still doing the
midbass in the kick panel area but taking the midrange and tweeter and
putting them in the dash or either just the midrange in the dash and
tweeter on the A pillar. I hate to go through all the trouble of building a
dash and not have it used for part of my sound. My thoughts on the dash
are to have the speakers as far away as possible from the listener.
Probably having a grille that covers up the parts of the dash where the
speakers are so you can't see them. One good thing about the midrange is
that it is completely closed off so there is no need for an
enclosure. Your thoughs on doing any of this? I just want to have
the best sound possible. I will also be using the Alpine H701 processor
so I will have alot of control with everything as well as being able
to use an amp per speaker set. 1 for midbass, 1 for midrange, and 1 for
tweeter.
This sounds like a great idea, and I am all for it. I can't tell you where
the speakers will need to go, but having the ability to put them anywhere is
a big plus. My suggestion is to pop the dash off and look around under
there. The locations will become more obvioous once you see what resides
below the dash cover. Keeping the AC and defroster shouldn't be a problem, especially with such small speakers for the front stage. And yes, the midbass in the kicks is a solid move. Looking forward to hearing how this goes. Send photos and ideas and I'll help you decide on a few preliminary spots for the mids and
tweeters to go.
Scott
I'm not using the dyn md140 or the md100's that came with the set in my truck right now. I even moved the md140 and tweet right beside the midbass and still had a problem with the stage lowering. I tried my hardest (without pulling the ac and heater out) to get my truck to image well from both seats but I couldn't get the pathlengths close enough so I made it a 1 seater. The next one I do will be a 2 seater but it definately won't be a daily driver.
I have nothing at all against the Scan drivers. My main concern was putting them in the door and having water get on them. Like I said, I am going to be using them on my next install. I've heard alot of great things about those drivers. I almost ordered some of the 4's to use for this install but I was already spent out LOLAnd I will also add, based on my experience with the Scans IB, is that somehow I got very little door resonance. You can see from the pics how much mass loading is there....not a ton, but enough. And still I was shocked how my doors hung in there. Not only that, but there was really no boominess on the top nor any muddyness on the bottom. Just not a lot of snap and and raw impact that feels like a sledge hammer to the sternum. BUT, my oh my...... Smooooooooth and loooooooow....kind of like having a home theater system in your car, actually. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I love not hearing bass coming from the rear of a vehicle. I haven't heard many that you couldn't tell at some point. I've got my sub in the front now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifFor the first time EVER, I honestly could not locate my sub in the rear of the car...even dring heavy bass tracks that used to pull toward the rear. I attribute this to being able to cross these drivers over so low (and using the best sub in the world //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif). I could easly drop the HP down to 40hz, but then found that my stage seemed to sink to an undesirable level.
What 8 are you trying to use?I'm currently attempting 8's in the doors and if I cannot get them to work, back to the Scan's I go!! //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
