hey i was looking at some scanspeak revelators and other comparable diy mids and they all seekm to need a sealed enclose of a bout .25ft or so whats the best way to make enclosure for the mids to go in the door besides fiberglass
those aren't enclosures...
ive always wondered that. how does my door become the box, if there is basically no way to seal around the window "gasket"? its basically a big leak right there.infinite baffle.... seal the inside door panel from the rest of the cab and the whole door becomes the box.....
well i have my doors completly deadend with 2 layers of ss/raammat filled the holes with plexi have egg crate foam behind the speakes and ensolite on top of everything?infinite baffle.... seal the inside door panel from the rest of the cab and the whole door becomes the box.....
what about when i roll my window all the way down? my window goes down far enough that it completely clears the gasket leaving like a 1/4" wide gap almost all the way back to where the door handle is.Go to DIY and ask the same question. I have ran the Seas IB. Never had the Scans but you can get the answer quick on DIYMA. On the glass the window gasket works the same was as you not having a swimming pool in your door when it rains. Same idea as when using an entire trunk in IB. I am sure some air is going to make it in or out some how but its such a small amount that it doesn't affect the driver. Just my .2 cents on the process.
You're correct on a few things, but so far off on others that I don't even know where to begin to straighten it all out. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Read what Genxx said.Scan Speak drivers are made for realistic musical production and if you aren't going to install them right then you are just wasting money. Like I said, those components are NOT made for vehicle use so they are not treated for moisture and if they get wet....well...there goes $400 They need to be in a sealed enclosure or an AP enclosure. When you hear people talk about how good these sound it has ALOT to do with the installation and tuning. Just because it is one of the best midranges doesn't mean that you can just throw it in somewhere. And yes, very strong fiberglass enclosures. I'm going to go ahead and tell you....making an enclosure for a midrange/midbass can cause you alot of headache. If you don't get that thing where it doesn't doesn't resonate it is just going to sound like pure ***. You may want to look for something in a car audio line that you can put in the doors and just use the door for the enclosure. I'm not telling you not to do it...but it isn't going to be easy to make it sound right by any means. If you want something that has a good thump, has the ability to play loud and handle lots of power I would say go with a Dynaudio.
