Eliminating Speaker Noise (from amp to head unit)
nba1341
LA
Ok so I have a constant noise in my speakers that does not variate when the volume is turned up or down (only goes away when volume is turned to 0). The noise is there with the car on and off (in acc mode) and I know its not engine noise or alternator whine because it doesn't fluctuate nor is it a popping its more like a static.
I have pin pointed it to my stereo patch cables that go from my amplifier into my head unit. They are cheap blue ones which are not twisted or anything so here is my question.
To get rid of this noise should I buy some of those more expensive twisted cables that are suppose to eliminate noise
or should i buy 2 ground loop isolators and hook them on my old cables
which do you think would be a for sure fix because I don't want to dump my money with no results.
This sounds like floor noise. Are you POSITIVE your gains are set correctly? I had this EXACT hiss coming from my highs for a long time.
What HU and what preout voltage are you running?
Also what amp?
performance teknique amp icbm775 50W x 4ch
its in a 65 mustang the headunit is made by custom autosound rated 240 watts
ive had 2 different head units but both have noise
i moved my power wire to the other side of the car and it significantly decreased the noise
could it be my cheap rca cables?
my grounds are good although one is in the back of the car (the amp) and the head unit one is in the front
just unplugged rca cables from head unit and directly into my ipod (using one of those component to line out things) and the noise is still their so its definitely not the head unit
Oh yea i forgot to mention i also plugged my ipod directly into the amp where the rca cables are supppose to go and no noise
so im guessing i have found my problem in the rca cables themselves
so now do you guys thing better quality twisted/copper cables will do the trick or am i still going to have noise?
You may have to go with shielded RCAs. I am not an old car guy and maybe there is something with the stock wiring that is different from today's cars. Good that you got it narrowed down though.
nba1341
nba1341
LA
loopkiller
