Electrical Upgrades
mackin
srsly
I am getting ready to order my system, but i'm not sure what i'll need as far as electrical upgrades go.
I will be running an eD nINE.1 at 1 ohm and a nINE.2 at 4 ohms.
That will be a total of about 1400 watts.
I figure i will at least need to do the BIG 3, but i was wondering if a second battery would be in store? i'm also not sure how the second battery really works, so if anyone has an explanation of how it's wired etc that would be awesome. Also what battery would work well if i do need one?
My car is a 1999 Mazda Millenia S and I'm almost positive it has a 110 amp alternator. will having a second battery put more strain on it?
sorry for being a noob on electrical systems.
thanks in advance //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Before the second battery you should replace your stock battery with a deep cycle. Kinetik or Powermaster are good brands. Buy the largest one you can fit under your hood. If you still have voltage issues then consider needing a HO alt or second battery.
i was looking at yellowtops. would that be solid under the hood?
if you can fit it a kinetik 1400 or 1800 in back and be done with it.
will my alternator be able to handle charging both batteries? and what should i know about hooking the battery up?
thanks for the replies. any other input?
mackin
srsly
mackin
Plymouth, MN
mackin
