electrical probs
probmxstyle
The Well Dressed OG
1,293
MD
I was participating in a stereo comp at a local car show this morning when my head unit cut off. It had done this befor and I know that i was supposed to run a power wire right to the battery. I had the power wire hooked up to a brown wire with a white line and the ign wire hooked up to a yellow wire with a green line. (Now that i torn some things apart i found that they are related to the air bag)After it cut off and wouldent come back on I noticed that my air bag light was on and with the car off the seat belt would not retract. Only with the car running would it retract or move at all. i checked all my fuses and they are all ok. Do you think i could have blow a fusable link or something? i am not getting any power out of either the yellow or the brown wire. Ohh and also my clock doenst work either.
you messed with the wrong wires.
IIRC air bags have a connector that shuts stuff off if you are in an accident.
1 thing not to fool with are things related to the airbag
you messed with the wrong wires.IIRC air bags have a connector that shuts stuff off if you are in an accident.
Any idea what this connector looks like or were it may be located? Could that cause the seatbelts to no retract when the car is off?
sell it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
there is a black market for them because they cost so much to replace
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
Update: The burning smell is slowly going away at middle volumes. To the point where it only comes on at middle volumes. I adjusted the sub master...
17
4K
probmxstyle
The Well Dressed OG
probmxstyle
MD
DJ Riggz
    Jun 1, 2024
    May 31, 2024
