electrical for Q1-4500
Did you ground the alt?
yeah the alt is grounded also, have it on the ground to my d3400
---------- Post added at 12:53 AM ---------- Previous post was at 12:52 AM ----------
Did you actually check your grounds with a dmm or did you just sand to metal and throw it on?
Sent from my SGH-T999 using Tapatalk
its grounded to my battery, and how do I check grounds with a dmm?
i had 4kw on a stock 130 amp alt and two 240ps never went below 13.4 or so..
it shoulb be hitting way hardeg. i mean like them havocs should be begging for help.
measure output abd se if you are getting more power.
---------- Post added at 03:42 AM ---------- Previous post was at 03:41 AM ----------
sounds ljke a bad connection if your not getting much more output
Take a multimeter. Can get one at walmart for 20$.
Set to ohm resistance. Put one end on the negative of your battery. Put the other end on your ground. Anything above 0.6 or 0.8 is bad
thanks ill check it out
Problem is the Mechman. No way on a single 4500 you should be dipping into the 12s with a 370a alt. A single group 31 in the back would be sufficient if the alt is indeed pumping out 370a.
are you slow? this was when i had only 65 AH total. stay off my thread man
BassAndBeer
BassAndBeer
California
ObTechAudio
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
